Glanza_cl Posted March 27, 2009 Posted March 27, 2009 erm kinda, you can bloc up the bov or completely remove the reserc bov but if you still have the standard air box you probably wont hear it.if you buy and open air filter then yes you would hear it, so can your hear chatter on a standard engine not really...get a open filter then yes. Quote
SooperD Posted June 5, 2009 Posted June 5, 2009 it is very quiet with the airbox in place.. Ive now got a blitz SUS and its mega loud and sucky.. altho it gets annoying after a while Quote
pick Posted June 5, 2009 Posted June 5, 2009 no you wont be able to hear the chatter with standard air box on take it off put a uprated filter on i u will hear it then if u put front mount on with that lil extra air pressure it will be very loud Quote
SooperD Posted June 6, 2009 Posted June 6, 2009 Yea id advise against it.. makes your car slower between gear changes too.. Obviously rather than your turbo continuing to spin when u lift of to change gear, the back pressure actually slows the turbine down therefore needing to respool thus giving u less performance. I noticed a massive difference going from my HKS SSQV to having chatter.. Car was soo much faster between gear changes . Quote
