okay guys i have a glanza v and a gt sitting that am breaking i am wanting to build a 4EFTE 1.5
so was wanting to know who has done it and is there a list of every single part i will need and if ther are any parts that i need to modify to make this work i have been having a read though the forum and there are quite a lot of mixed views and opinons
cheers :lol:
check out
hardcore.ep91.com
the 5e-fte has been disected to death by rory.
my opinion, if you have the parts to hand do it. and if your gona forge an e series motor then why not,
if your not forgeing stick wtih the 1.3 as its totaly capable
check out
hardcore.ep91.com
i was wanting to go to 1.5 the plan is to build it up i got plenty of spair time i want to make a monster ep
i went on to that site but cant see any thing saying all the parts that are needed :lol:
hey mate
if your after a near complete list of whats needed for the 5e conversion the pop over to tgtt in the engine technical section there is a whole thread to it and its fairly comprehensive looking.
nic
ok guys found this any one got any amendments or extra needed
For an OEM 5efte CT9 buildâ?¦â?¦hereâ??s the spoon feeding list for allâ?¦â?¦â?¦
- 4efte rocket cover
- 4efte or 5efhe/fe headâ?¦with either 4efte or 5efhe cams (MARGINALLY better)â?¦..make sure u keep the shims with whatever cams u useâ?¦or reshimming may be necessary
- 4efte head gasketâ?¦5efhe or trd head gaskets are also used (but trd raise compression somewhat)
- 4efte intake manifoldâ?¦5efhe ACIS can be use, but usually requires something to operate it properly
- 5e block
- 4efte pistons or some people shave the 5e pistons (TRIED and PROVEN by MANY),,,in fact some people shave the 4efte pistons��but then a lot of u guys are afraid to do this,,,,,,,,so stick to the oem 4efte ones then
- 4efte piston rings, if u use 4efte pistons���..5e pistons rings if u use 5e psitons���there is a difference in part numbers,,,,,,,,,but people have been know to use any set with any pistons and they work fine
- 5e rodsâ?¦5efhe preferred for bigger boost,,,,,,,,5efe rods can be used if u donâ??t plan to over do it
- 4e/5e cam gear/wheel...set timing using 5e mark.........and set base timing at 10 degrees.........or as desired, as some may want to retard base timing depending on set up and gas quality
- 4efte injectors at MINIMUM
- 4e/5e oem fuel pressure regualtor or aftermarket unit...run anywhere from 2.3 to 3 bar on initial set up,,,BUT depends again on your set up......tune to suit
- 4e/5e fuel rail
- 5e idler and tensioner pulleys
- 4e/5e crank gear
- 5e tming belt
- 4efte ecu, harness and map sensor at minimum.....the greddy ultimate on the 5e ecu or 4efte ecu is also great for fine tuning...
- 5e crankâ?¦..some prefer 5efhe crank (stamped â??5eâ?ÂÂ) on itâ?¦â?¦while others use the â??3eâ? marked crank which comes in some 5e blocks
- 5e thrust washers
- 5e flywheel (200mm)��or redrilled 4efte flywheel (212mm), again, has been done several times, just make sure you have a competent machinist���OR try to get the 5e bolt pattern flywheel that holds the 212mm clutch set up (usually found on some 3E engines)
- 5e clutch and 5e pressure plate OR 4efte clutch and 4efte pressure plateâ?¦.NOT to be mixed and matched
- 5e/4e oil pumpâ?¦â?¦â?¦.make sure u get the one that matches what is thereâ?¦â?¦â?¦as far as Iâ??m aware they are two types
- 4e or 5e oil relief valve
- 4efte oil pick up and 4efte sump�OR 5e oil pick up and 5e sump�.to be used together and not in combinations���i.e. choose one and use both units together�..note,,,u wouldhave to drill and tap the 5e sump for the oil return
- 5e connecting bearingsâ?¦make sure u get the correct sizes---check the back of the used one
- 5e main bearings ---- make sure u get the correct sizes---check the block and crank and do some adding of the numbers or check the back of the used one
- 4efte exhaust manifoldâ?¦BEWARE a custom unit is preferred as the oem unit is VERY restrictive on the 5e
- 1 ct9 turbo and downpipe with all gaskets ---IF u are going to use the ct9 turbo for a short while��also, your muffler may need a slight extension as the 5e block is about 10mm taller�..else use whatever set up (turbo) u plan to run along with supporting exhaust manifold and downpipe
- 4e/5e water pump and hoses
- 4efte thermostat, housing and sensors
- 4e/5e gearbox/transmission
- 4efte distributor or 5efhe distributorâ?¦..same basic unit
- 4efte plug wires
- 5e timing covers
- 5e oil/dip stick and housing
- 4efte TMIC----NOT the best idea,,,but would work for ct9 set upâ?¦..if u already have a FMIC set up,,,use it back
- 1 gallon oil
- 1 pouch of sealant
- 1 oil filterâ?¦4e/5eâ?¦same thing
- 1 gallon coolant
- 4 spark plugs
- 1 cam shaft seal
- 1 crank shaft seal (front)
- 1 crank shaft seal (rear)
- 2 turbo water lines if required---depends on turbo unit use
- 1 oil line
- 1 oil return line
- all rubber gaskets
- all other asscessories from 4efteâ?¦.a/c, p/s, alternator, etc
areas to be cautious of:
- power steering pump....u may need to custom make a bracket or just use the adjuster piece to hold it in plac
