have they got the same front hub setup............? will the suspension fit anti roll bar brake caliper fit?? seem to have sorced one in a local scrappy and he only want £5 for it ??
mate all i can tell you is i upgraded my brakes to paseo ones and the hub has a different spline count to na starlets but i belive its the same hub as the later gts and glanzas as they have the bigger brakes that the gts have! your suspension will fit and all your bottom arm etc i think your brakes will fit too but the spline count is different so you would need the paseo driveshaft which will fit straight into the gearbox cup!
