Papa_Nicole Posted April 7, 2009 Posted April 7, 2009 I've just bought a new starlet ep82 advance quadlight, I've got a upgraded manifold without the restriction in number three, would a hybrid ct9 running with my current setup (wepr fmic, relocated air filter to front, manifold, fuel pump, toms ecu, profec type s boost controller) give a sizable enough increase of power, or in your opinion should i look to a different turbo altogether, also im situated in the london/kent/essex area is there any recommended specialists who can supply and assist in safe installation. Also with my standard turbo im running one bar, can i push it more?? Quote
keirz Posted April 7, 2009 Posted April 7, 2009 i wouldnt recomend over 1 bar on the ct9. would not see any benifits as the increased heat will kill the performance gains.a hybrid is always something you could try, will bolt straight up to your current set up and may see around 200bhp. Quote
Papa_Nicole Posted April 8, 2009 Author Posted April 8, 2009 i wouldnt recomend over 1 bar on the ct9. would not see any benifits as the increased heat will kill the performance gains.a hybrid is always something you could try, will bolt straight up to your current set up and may see around 200bhp.cheers yeah i did think hybrid was a good option, just dont wana spend the cash and be dissapointed lool Quote
