LarQ98V Posted April 8, 2009 Posted April 8, 2009 Just got a monstermotor air filter relocation kit and have heard boost creep can be a problem wit these....anyone experienced this wit this fitted? Quote
Glanza_cl Posted April 8, 2009 Posted April 8, 2009 it's gonna happen with almost any front mount filter as there is a greater force of air being able to enter the turbo, it will have with a monster monster sport one, toy tuning, and any home made one.there isn't alot you can do, if you haven't already go get the turbo's wastgate ported this will help with the boost creep also a good electronic boost controller with help control the boost levels slightly so with both of those you should be able to control/get rid of boost creep Quote
montanajr Posted April 8, 2009 Posted April 8, 2009 Have a look in the turbo tech guides section on how to port your wastegate bud. Quote
LarQ98V Posted April 9, 2009 Author Posted April 9, 2009 Cheers fellas Mite just fit the kit in the original air box position for the time being....cash is abit tight. Quote
paulgtt Posted April 12, 2009 Posted April 12, 2009 Are you running with a decat??If you have the standard cat still in place it won't boost creep Quote
LarQ98V Posted April 13, 2009 Author Posted April 13, 2009 Are you running with a decat??If you have the standard cat still in place it won't boost creep Good good , only a standard exhaust system at the moment....one plus point of it i suppose! Quote
guy86 Posted December 17, 2009 Posted December 17, 2009 i think ul find it will boost creep mine does and I've still got the cat on, trying to solve the problem now. Quote
