Okey, my check engine light pops up when driving ~75 mph (max speed on dutch freeways)
I just did a diagnostics test, and came out with 2 fault codes.
this is what I got:
34: turbo pressure signal
42: VSS, 2000 to 5000 rpm, coolant temp over 80 degrees, injector duration over certain value, and no VSS signal.
can some of u guys tell me what I have to do to fix this problem?
I don't have any clue how to solve this?
any help is appreciated!
thanks in advance...
Okey, so I hit fuel cut one time when adjusting the actuator...
so 34 is sorted.
I dont have an oil temp gauge, but the temp of the coolant is just fine, just below the middle.
but 42 means No Verhicle Speed Sensor?
then it has to be something with my ECU or something?
thnx for the info mate.
this is what I found on the dutch forum about it:
Code: 42
Signal: Vehicle Speed Sensor
Diagnosis: No speed sensor signal to ECU when loaded driving condition with engine speeds 2000 to 5000 rpm. for 8 seconds or more.
Common Trouble Area: VSS,ECU
