alright ive been doing some searching on this because it seems to be every 3rd day or so im reseting my ecu. it seems to be boosting fine in low revs but as it goes up the revs it seems to be strugling, the boost guage is showing normal but it doesnt feel right. i did a diagnostic and the only fault that came back was 34 which i think is fuel cut? anny suggestions on this?
Yeah check your actuator.Make sure none of the hoses are crimped over because the boost want cum through properly,like a found out.
yeah 34 is fuel cut, you sure the boost gauge is ok?
check the plugs if it's hesitating, check the actuator is ok.
i did a compression test last week so i checked the plugs and they looked fine
I've checked the atuator, i was getting it with the standard actuator then i fitted a hks 1 and it went away for a while.
thanks lads
