rox Posted April 18, 2009 Share Posted April 18, 2009 hi,i've got a squeek coming from the n/s/f suspension on my glanza any ideas what it could be and how to stop it? its happening when i go over any slight lump or bump in teh road gets quite annoying aswel!!! Quote Link to post Share on other sites
Glanza_cl Posted April 18, 2009 Share Posted April 18, 2009 have you got lowing springs on? might just be a foobed shock. you checked the top mounts? Quote Link to post Share on other sites
BAZ2CRAZY Posted April 20, 2009 Share Posted April 20, 2009 Checked the top mounts are nice and tight?Mitch Quote Link to post Share on other sites
rox Posted April 20, 2009 Author Share Posted April 20, 2009 the car is fitted with JIC magic coilovers with adjustable top mounts all round?the top mouths have a large nut in the center and samller bolts around the outer which would i ned to tighten? Quote Link to post Share on other sites
BAZ2CRAZY Posted April 20, 2009 Share Posted April 20, 2009 ah i see, well it would be the nuts/bolts holding the adjustable top mount to the struts on the car.There should be three each side.Mitch Quote Link to post Share on other sites
rox Posted April 20, 2009 Author Share Posted April 20, 2009 thanks alot guys the 4 manin 10mm nuts that hold the shocks to teh turret housing well 2 were tight but the two that also hold the strut brace in had worked loose both sides!rep addedcheers Quote Link to post Share on other sites
rox Posted April 20, 2009 Author Share Posted April 20, 2009 lol just realised dont think u can add repcheers all the same!!!! Quote Link to post Share on other sites
rox Posted April 21, 2009 Author Share Posted April 21, 2009 ok we have a slot worse problem nowi thought this has cured the problem but seams it has notso todasy i removed teh wheel to close inspect the problem and the spring has snapped off leaving about a 4 inch peice of it broken away!!!this is obviously now a saftey issue!!!any suggestions of a cure for this or can it still be driven before replacing them? Quote Link to post Share on other sites
BAZ2CRAZY Posted April 21, 2009 Share Posted April 21, 2009 Put the standard shocks and springs on?You shouldnt really have it on, it will only cause further damage.Mitch Quote Link to post Share on other sites
RobSR Posted April 21, 2009 Share Posted April 21, 2009 ah i see, well it would be the nuts/bolts holding the adjustable top mount to the struts on the car.There should be three each side.Mitchits the massive one in the middle normally, not the ones that hold it to the chassis. Quote Link to post Share on other sites
RobSR Posted April 21, 2009 Share Posted April 21, 2009 ok we have a slot worse problem nowi thought this has cured the problem but seams it has notso todasy i removed teh wheel to close inspect the problem and the spring has snapped off leaving about a 4 inch peice of it broken away!!!this is obviously now a saftey issue!!!any suggestions of a cure for this or can it still be driven before replacing them?you dont want to be driving it with a snapped spring lol, i would recommend you find replacements Quote Link to post Share on other sites
BAZ2CRAZY Posted April 21, 2009 Share Posted April 21, 2009 its the massive one in the middle normally, not the ones that hold it to the chassis.I was talking about freeplay between the top mount and the chassis..Not the nut holding the shock to the top mount.Mitch Quote Link to post Share on other sites
rox Posted April 21, 2009 Author Share Posted April 21, 2009 i dont have stock suspension so will have to source some not going to drive the car after today until it sorted!!! more bloody expense! Quote Link to post Share on other sites
