dj-jon-boi Posted April 25, 2009 Posted April 25, 2009 i have hks actuator on my glanza. its currently running at 0.6 boost and i want it at 0.8 boost. can someone tell e how to do this, i know its by adjusting the thread but i just dont know how much by. other thing is my high low boost controller is not wokrkin as the actuator doesnt have any where i can plug one of the pipes out of the high/low controller unit to it.... Quote
Maz90 Posted April 27, 2009 Posted April 27, 2009 i have hks actuator on my glanza. its currently running at 0.6 boost and i want it at 0.8 boost. can someone tell e how to do this, i know its by adjusting the thread but i just dont know how much by. other thing is my high low boost controller is not wokrkin as the actuator doesnt have any where i can plug one of the pipes out of the high/low controller unit to it....First off you will need a decent boost gauge to tell you exactly what your running,then really its just trial and error.Just got to adjust a little at a time,then take it a drive and make sure its not hitting fuel cut.As for the high/low,you need a t-piece to connect all the hoses together. Quote
Guest dominodon Posted April 28, 2009 Posted April 28, 2009 x2 you need a good boost gauge or it be a waste off time,Short the rod is more boost- longer is less boost do 1 turn at the time then go from there. Quote
dj-jon-boi Posted May 3, 2009 Author Posted May 3, 2009 yea I've turned it 2 full turns, its runnin just under .7, im wanting .8 is this ok to run it at this boost? Quote
Glanza_cl Posted May 3, 2009 Posted May 3, 2009 yes thats fine,you can run it just under fuel cut which is around 0.85 (dependant on the car) but you got to take into consideration boost creep when the weather is cold, if you can adjust the actuator to 0.8 and not hit fuel cut then that will be fine but dont be suprised if you hit fuel cut on a cold night. Quote
