AaronW Posted June 5, 2006 Posted June 5, 2006 as the title says ,whats better,as i have an rx7 top mount intercooler which is great but i think a front mount looks the mutts,so whats the pro's and cons of them both,any relpy would be grateful! Thanks..Aaron Quote
lobotomy Posted June 5, 2006 Posted June 5, 2006 TMICPros:Not much... Does the job up to a pointShort piping route aids spool upLower pressure drop across coreCons:tends to suffer from heat soak, especially when stationaryLess airflow over finsProbably won't be suitable for lots of boost or a bigger turboFMICPros:Looks Good Better cooling as the core is directly in the flowLess HeatsoakWill allow you to upgrade turbo/run more boost further down the lineCons:Introduces a bit of lag - time it takes for the turbo to fill the coolerLength of piping also introduces a bit of lagThat's just off the top of my head. Anyone else can comment on there opinions. Quote
ben_j Posted June 5, 2006 Posted June 5, 2006 frount mount is better basically if you want power Quote
lobotomy Posted June 5, 2006 Posted June 5, 2006 Yeah an ideally sized FMIC probably won't cause noticable lag. Just don't go to big for the turbo you're running.My big bro runs a pretty monster FMIC on his S13 and you can see it's effect on his power graph - But there isn't much noticable lag when driving. Quote
Guest Enzo Posted June 6, 2006 Posted June 6, 2006 for evey day conditions an uprated top mount is more then adiquate up to a point,and because of the shorter inlet tract aids responce.if you check most scoobys/pulsars and the like all stick with the more inificient top mount when turning up the boost.im after an arc top mount, aparently good for 200bhp Quote
