topped up to nearly full at start of week and now its close to the low mark. is a leak at the rear main oil seal enough to loose that much or could i be burning oil too. also my exhaust is quite smokey. black when i first start it up.
it must be burning oil too, it takes just under a litre of oil to top up from the min mark to max mark on the dipstick so thats a lot of oil to loose from an oil seal
Guest dominodon
x2 Get that oil leak sorted or it will leave to more problems, Then go from there.
