Hey guys i`ll be starting the prepping for the 1.5 turbo build, but does anyone have the tolerance`s and torque settings anywhere for the engine? I've had trouble before getting a manual for imported cars :thumbsup:
Also id like to use the 5e cams as I've heard there a bit better but do i need to use the cover aswell? as the vent hose is in the wrong place and is smaller :S
cheers
Pm joz, lovely chappy he might be able to help with the tolerance and torque settings (hes just done a 5E build)
The FTE cam cover has 2 "holes" as it were you can get away with using the FE one which has just the 1 "hole" but i guess the crank pressure in turbos is higher so id get the FTE one..
sorry bit of a noob answer...someone mabe add/delete bits?
theres a full 5e pdf manual on this site, cant remember where though, your gona have to search for it though. tells you everything you need to know on building your 5e
