could some please explain to me the differences between the rear shockers on starlets. i now understand the sitiuation with the front ones but i am still unsure with the rear.
what are the differences regarding early and late EP82 dampers?
will ep91 rear dampers fit early EP82T (1991) top mounts?as i now have a 1991 glowing badge type gt starlet with shafted rear shocks. i have two used dampers off my ep91 SR, can i fit the shockers to the car or will i have to get the matching topmounts?
i thought that all rear shockers were the same all the way through but bilstein list them differently.
any info appreciated
welel the normal na starlets have two rear pins holding them onto the strut, same with the ep82 gt aswell,
on my old sr i interchanged them with each other,
i also think this is possbile with glanza rear shox but id have to go out and check to see if they have three pins,
sorry i mean the two threaded pins that you slot through the strut top and secure with nuts,
does that make sense?
