gtmuzz Posted June 17, 2009 Share Posted June 17, 2009 Sorry If this is in the wrong section! Got an ep82 starlet, basically standard. Its got a bailey BOV,cat back exhaust and a blitz filter.so far Ive changed the plugs , uprated the leads, serviced it , changed belts and some gaskets, basically cleaned it up and gave it a bit of paint So I was bored yesterday and decided 2 make my own relocation kit for the air filter,to make it into the bumper.Piping was no problem had plenty spare bits kicking around.But need to know what to do with the 3mm piping that went 2 the standard pipe?Do I still need 2 attach it 2 my new piping?Also the problem with the boost rising, causing the fuel cut. What would be the quickest and more importantly the cheapest way 2 solve this?????Some help would be much appreciated ta Quote Link to post Share on other sites
Sparky Posted June 17, 2009 Share Posted June 17, 2009 The 3 pipes going over the cambelt cover is for the hi/lo boost solenoid.When/if you upgrade to a HKS actuator, you can get rid of the lot, but for now I am sure you can just block the pipe off that isnt going anywhere due to the filter relocation.Boost creep is always going to be a problem with the shorter intake, try restricting the induction kit by warpping something wround it to stop as much air getting in.But the best way is to get an adjustable actuator (holds boost better) and port the turbo wastegate Hope this helps Quote Link to post Share on other sites
Dstillie Posted June 17, 2009 Share Posted June 17, 2009 Very Clean looking bay you have there Quote Link to post Share on other sites
Bluebear Posted June 17, 2009 Share Posted June 17, 2009 I think dub_se7ven used a bit of plastic foam (the kinda stuff you can find in packaging sometimes) wrapped around his to combat boost creep. Quote Link to post Share on other sites
gtmuzz Posted June 17, 2009 Author Share Posted June 17, 2009 Cheers for your help lads:)!!!Just put the original piping back on the car (as it is in the picture) and its still over boosting causing the fuelcut again, Is this normal or have I fcuked somthing?HELP!!! lol Quote Link to post Share on other sites
dave200 Posted June 17, 2009 Share Posted June 17, 2009 a blame it on your driving you madman lolstill up for crail next month the circuit day? Quote Link to post Share on other sites
gtmuzz Posted June 17, 2009 Author Share Posted June 17, 2009 dave200 said: a blame it on your driving you madman lolstill up for crail next month the circuit day?Dont know man , u still going??do u know why its still overboosting? Quote Link to post Share on other sites
dave200 Posted June 17, 2009 Share Posted June 17, 2009 did you connect all the pipes up in the exact same place (easy to do a still do it n a do this for a living lol) if your not sure nick over n compare them to mine Quote Link to post Share on other sites
gtmuzz Posted June 17, 2009 Author Share Posted June 17, 2009 dave200 said: did you connect all the pipes up in the exact same place (easy to do a still do it n a do this for a living lol) if your not sure nick over n compare them to mineObvcourse a put the bloody pipes in the right places cheeky *unt loleverything is where it should be!Apart from i took the aircon out but left the pump due to not having the non aircon belt!Would the aircon affect it? Im confuzzzed! Quote Link to post Share on other sites
dave200 Posted June 17, 2009 Share Posted June 17, 2009 dont no tbh mate doubt it because its still running the pump ill fone the almighty kenny n ask Quote Link to post Share on other sites
gtmuzz Posted June 17, 2009 Author Share Posted June 17, 2009 gtmuzz said: !!!Just put the original piping back on the car (as it is in the picture) and its still over boosting causing the fuelcut again, Is this normal or have I fcuked somthing?HELP!!! lol Anybody else any ideas?? Quote Link to post Share on other sites
