Will these fit? im confident they will but wanted to double check with u Chaps prior to buying.
4x100, Offset 38, Width 6J
Sorry, noob question.. did try searching but to no avail.
Need a quick response because these wheels r ending on ebay tomos :lol:
Thank-you
One thing these guys forgot, check the centre bore of the wheel, if it's smaller than 54mm, they won't fit unless you bore the hole out, aftermarket wheels tend to have a removable spigot ring, but standard wheels don't, so check beforehand!!
The Starlet hub diameter is 54mm, I got the 56mm from my corsa as I attempted to fit the speedlines to the corsa, but to no avail will not fit without modification, you can get the spigot ring kits from halfords, they can become very unstable with just 4 bolts holding it to centre.
So if the centre bore is bigger than the Starlet size be sure to buy the correct spigot rings or else the wheel may just fall off.
Damien
Jaystar77 Agrees
Idrees Agrees
Bourkey Agrees
