My speedo needle does not move when i drive the car.
how do i remove the speedo?
Twist and pull the cable from the cluster. pull the cable from the firewall then remove the other end from gearbox
First things first, unscrew the dials cluster so that you can access the speedo cable. It can be a tight process especially if you have big hands.
Then follow nic's instructions. If you need more access remove the lower dash.
Joz
