Guest Enzo
please watch where your posting,
in this instance
TECHNICAL > exterior desgin
answering to your question, get a hair dryer or heat gun on the spoiler to soften the glue
If its bonded on really well then it can be really hard or impossible to remove without breaking it in half.
That is exactly what happened to mine.
I'd advise two things, pm Idrees on uksc because he has experience removing TTE spoilers or ask a decent local bodyshop for their pro opinion.
If the bond is too strong or permanent then there is not much choice.
Hope this helps.
Joz
I'd advise two things, Personal Message Idrees on uksc because he has experience removing TTE spoilers or ask a decent local bodyshop for their pro opinion.
Hope this helps.
Joz
removed it today well but hard lol
chipd the corner a bit
Im in the same situation as you, i have a glanza one to go on my SR. how did you remove it??
well flat screw driver and cloth and little hammer
and go easy dont hit the top corners though
because i will break off
maby try a little heat at the same time
its just stuck on no screws or that :)
