myatt!!! Posted July 6, 2009 Posted July 6, 2009 will i pass the emissions test with a de-cat and hks system?? dont imports do a 2 gas test- wat is this Quote
Guest Enzo Posted July 6, 2009 Posted July 6, 2009 not sure on the gas test, what type of starlet do you drive dude? Quote
molovin Posted July 21, 2009 Posted July 21, 2009 mine failed on emmisions today totally standard. Quote
Armand Posted July 22, 2009 Posted July 22, 2009 In my local mot center my Glanza passed mot with a full stainless system a week ago.Armand Quote
Steve GT Posted July 23, 2009 Posted July 23, 2009 if your cars an import it will pass an emissions testas theres no uk equivalent theres no uk equivalent to match it too so it only requires a basic emissions test otherwise known as a pre-cat testthe pre-cat tests ended in 1992 but a starlet turbo or glanza v is exept fom thesesll you have to do is make sure the MOT tester knows its a japanese import and when he logs it into the tester he wont have anything to click on so he fails the test on emissions and is then required to run a basic idle test which mine passed about a month ago with full afermarket exhaust including de-cat and my car was overfuelingso im pretty sure its nearly impossible to fail his wayhope it helps bud Quote
Russleh Posted July 23, 2009 Posted July 23, 2009 not meaning to hyjack but what if its a sportif with a glanza engine. what happens then. Quote
molovin Posted July 29, 2009 Posted July 29, 2009 Exactly what i thought a simple idle test. But my car failed on emmisions :-s Quote
Guest dominodon Posted July 30, 2009 Posted July 30, 2009 Your car shouldnt be failingin a standard glanza, Your lamba might be on its way out.Just to give you a idea my car on a td04- full system decat and it fails on the idle test. Quote
