  • 3 weeks later...
if your cars an import it will pass an emissions test
as theres no uk equivalent theres no uk equivalent to match it too so it only requires a basic emissions test otherwise known as a pre-cat test
the pre-cat tests ended in 1992 but a starlet turbo or glanza v is exept fom these
sll you have to do is make sure the MOT tester knows its a japanese import and when he logs it into the tester he wont have anything to click on so he fails the test on emissions and is then required to run a basic idle test which mine passed about a month ago with full afermarket exhaust including de-cat and my car was overfueling
so im pretty sure its nearly impossible to fail his way
hope it helps bud
Guest dominodon
Your car shouldnt be failingin a standard glanza, Your lamba might be on its way out.
Just to give you a idea my car on a td04- full system decat and it fails on the idle test.
