cleanshavenllama Posted July 6, 2009 Posted July 6, 2009 I followed this guide here about wiring my rear lights up, so that all four come on. The problem is now my fog is always on when i turn on my lights, im not sure where ive went wrong, any help would be appreciated be) Quote
Rickstar Posted July 6, 2009 Posted July 6, 2009 I think you left your fog plate on your cluster..lol.. you need to unscrew your cluster and take the metal plate off where the fog light should be. As this increases the brightness, which makes it work as a fog light.That should solve your problem. Depends which cluster you are using?! If it is then normal original one then this will be your problem. Rickstar Quote
cleanshavenllama Posted July 6, 2009 Author Posted July 6, 2009 yeh that was the problem, i have glanza lenses stuck on, so was not easy getting them off, but all sorted now. thanks mate :surrender: Quote
