jim808 Posted July 12, 2009 Share Posted July 12, 2009 ok the actuator is fitted I've ajusted it about as far as it will go. the part that actuator moves is sitting about 11 o'clock and won't go anyfurther and its still only boosting to 0.4 bar.has anyone else had this problem or can anyone help me outI'v also fitted a greddy bccThanks Jimbob Quote Link to post Share on other sites
Sparky Posted July 12, 2009 Share Posted July 12, 2009 The shorter the actuator arm the more boost it will run matePretty sure if you want to run .8bar the length of the arm upto the middle of the pin or hole should be around 128mm Quote Link to post Share on other sites
jim808 Posted July 12, 2009 Author Share Posted July 12, 2009 The shorter the actuator arm the more boost it will run matePretty sure if you want to run .8bar the length of the arm upto the middle of the pin or hole should be around 128mmThe length on mine is about 124 mill and it still the same i can't think what it could be. It was boosting more than that on standard actuator??????? Quote Link to post Share on other sites
Sparky Posted July 12, 2009 Share Posted July 12, 2009 Check you other thread mate I replied there maybe you go the wrong pipe connected Quote Link to post Share on other sites
Steve GT Posted July 12, 2009 Share Posted July 12, 2009 as sparky said above it sounds like its piped up wrongwho fitted it? Quote Link to post Share on other sites
