glanzap88 Posted July 15, 2009 Posted July 15, 2009 hi, does anyone no if you can fit any starlet lowering arm + droplink to glanza or has it got to be a specific one for glanza. Also does anyone no if the ep91 non turbo (sportif etc) front wing will fit a glanza. cheers much apreciated if you could comment ta Quote
Curtis Posted July 15, 2009 Posted July 15, 2009 not sure about the drop link but the wing will fit but it will have a side repeater hole you will have to drill a couple of holes for your sideskirt Quote
WallaceGlanza Posted July 15, 2009 Posted July 15, 2009 Yeah a lower arm from an na should fit, you can also buy new one's from tm-developments and their not too expensive, I knw there is a difference in the bush size on the lower arms between the gt's and glanza's but thats only a worry when replacing the actual bush. Quote
glanzap88 Posted July 16, 2009 Author Posted July 16, 2009 cheers guys thanks for the info brilliant ta Quote
