Project C.F.A Posted July 17, 2009 Posted July 17, 2009 Right im in the process of putting the 5efe engine into my starlet. Was just wondering what I will have to do to get it to start with the ECU being different to my originakl which my keys is for.Im only guessing but surely my original key is programmed for the 4efe ECU and wont work on the 5efe ECU?Am I correct? If so any one knwo how to get round it or what I need to do to correct it Cheers Liam. Quote
rob_bower Posted July 17, 2009 Posted July 17, 2009 im sure joz or dub will see this at some point to clarify but i seem to think joz used his 4e ecu when running his 5e!! Quote
Idrees Posted July 17, 2009 Posted July 17, 2009 No mate keep the 4EFE you will be fine with that ECU. It has a slightly higher rev limit too, so other people have chosen to stick with the 4E ECU. Quote
Project C.F.A Posted July 17, 2009 Author Posted July 17, 2009 Thanking you people ill get cracking then Quote
Jozinobi Posted July 18, 2009 Posted July 18, 2009 4EFE ecu will run the 5EFE in a starlet fine.It will run you lean higher up but is safe.Ideally you want the 5EFE ecu in there and it is a key transponder issue.Make sure to use your old 4EFE throttlebody as it has the correct sensors, the 5EFE one has different ones.Good luck with the conversion and hope you feel a refreshing difference.Keep us updated on your progress Joz Quote
Starlet SR Posted July 28, 2009 Posted July 28, 2009 is there any other sensors you need from your 4e to run the 5e besides the tb Quote
