in order to sort my loom out, one of the problems i need to sort is the lambda sensor. basicaly the sensor that screws into the top of the decat pipe has a 4 pin plug on the end of it. cant match this up on the engine loom? anyone with a gt go out and check for me?! pleeeeeeeeeeease :D a pic would be great if possible :D
thanks everyone
there's two a lamber and an O2, the lamber should connect to a plug that sits just above the gearbox or near the coolant temp sensor (mine is green not sure about others).
yeah thats right, lambda is the top one..
reason i ask is, the sensor its self which has about 7 inches of wire leading to a plug is different i think to a standard glanza. if you were to check on the glanza or GT i bet you would only see a 1 pin plug connecting to a 1 pin plug with a white wire comin out the back on the engine loom... well ive got that bit, but my sensor wire and plug is a 4 pin fitment... and cant find a plug that matches on the loom?!
the sensor came with my decat pipe, my loom came seperate. only think i can narrow it down to is that the guy before was running a wideband AFR? had some kind of harness to plug into the other sensors.
anyone else shed some light? all i know is the plug on the loom will not fit into the sensors plug at all, square peg round hole. so im guna have to get a new sensor or do an apollo 13.....
