200sx-Starlet-Jay Posted July 18, 2009 Share Posted July 18, 2009 in order to sort my loom out, one of the problems i need to sort is the lambda sensor. basicaly the sensor that screws into the top of the decat pipe has a 4 pin plug on the end of it. cant match this up on the engine loom? anyone with a gt go out and check for me?! pleeeeeeeeeeease a pic would be great if possible thanks everyone Quote Link to post Share on other sites
Asad Posted July 18, 2009 Share Posted July 18, 2009 Isn`t the one on the De-cat just a temp sensor? Quote Link to post Share on other sites
Glanza_cl Posted July 18, 2009 Share Posted July 18, 2009 there's two a lamber and an O2, the lamber should connect to a plug that sits just above the gearbox or near the coolant temp sensor (mine is green not sure about others). Quote Link to post Share on other sites
200sx-Starlet-Jay Posted July 19, 2009 Author Share Posted July 19, 2009 there's two a lamber and an O2, the lamber should connect to a plug that sits just above the gearbox or near the coolant temp sensor (mine is green not sure about others).yeah thats right, lambda is the top one..reason i ask is, the sensor its self which has about 7 inches of wire leading to a plug is different i think to a standard glanza. if you were to check on the glanza or GT i bet you would only see a 1 pin plug connecting to a 1 pin plug with a white wire comin out the back on the engine loom... well ive got that bit, but my sensor wire and plug is a 4 pin fitment... and cant find a plug that matches on the loom?! the sensor came with my decat pipe, my loom came seperate. only think i can narrow it down to is that the guy before was running a wideband AFR? had some kind of harness to plug into the other sensors.anyone else shed some light? all i know is the plug on the loom will not fit into the sensors plug at all, square peg round hole. so im guna have to get a new sensor or do an apollo 13..... Quote Link to post Share on other sites
WallaceGlanza Posted July 19, 2009 Share Posted July 19, 2009 Glanza lambda sensor and cat temp sensor:Lambda plug: Quote Link to post Share on other sites
