Bildo Posted July 29, 2009 Posted July 29, 2009 I have purchased an E-Manage Blue main unit with a TRUST N-8 loom (suitable for S14/S15's) can anyone tell me what harnesses and optional extra bits I would need to run a basic 200BHP setup on a 4EFTE?Thanks guys. Quote
WallaceGlanza Posted July 29, 2009 Posted July 29, 2009 Do you not keep your msn conversation logs!? Quote
Bildo Posted July 29, 2009 Author Posted July 29, 2009 Do you not keep your msn conversation logs!? Only our dirty conversations, baby.But.. No, so help. http://www.rhdjapan.com/jdm-low/TRUST-E-Ma...ss-Toyota-17132That, with injector harness, boost harness and boost sensor? Quote
WallaceGlanza Posted July 29, 2009 Posted July 29, 2009 Their not for others eyes.That harness wont be a direct fit, there's no "plug and play" harness for the ep82/ep91. All you want is the main universal harness which will have to be spliced into the ecu loom or into a field harness if you want to buy one of them.After that you want the injector harness and ignition harness so you have the full adjustability possible from the emanage blue. If you're planning on running much over 1bar then you also want the pressure sensor and harness. Quote
Bildo Posted July 29, 2009 Author Posted July 29, 2009 Thanks mate, so either way whether I have the normal harness or a field extension harness it will have to be spliced into the ecu loom I'm assuming?I have the injector harness, need the ignition harness though. Quote
WallaceGlanza Posted July 30, 2009 Posted July 30, 2009 Well the field harness acts as an extension and plugs into the ecu harness meaning you don't cut the actual wires on the car just on the field extension harness. But there isn't a plug and play option. Quote
