joel_ep91 Posted August 2, 2009 Posted August 2, 2009 ok guys and girls the valve stem oil seals have went on my n/a so have decided to do a bit of head work while the head is off. have the trd 0.6 mm gasket for it turbo cams for more lift and duration, and the head ported and polished.but the guy took a 1mm off the head was woundering would the clearance be ok with the 1mm off the head and the o.6 gasket or has there been to much taken off.thanks for any help rep added cheers joel Quote
japcarmaniac Posted August 4, 2009 Posted August 4, 2009 ok guys and girls the valve stem oil seals have went on my n/a so have decided to do a bit of head work while the head is off. have the trd 0.6 mm gasket for it turbo cams for more lift and duration, and the head ported and polished.but the guy took a 1mm off the head was woundering would the clearance be ok with the 1mm off the head and the o.6 gasket or has there been to much taken off.thanks for any help rep added cheers joeljust get another head if your in doubt. Quote
Driver Posted August 5, 2009 Posted August 5, 2009 nah be a treat that bet it feels miles better at high revs compression will be mega high now so will pickup better at higher revs Quote
joel_ep91 Posted August 5, 2009 Author Posted August 5, 2009 nah be a treat that bet it feels miles better at high revs compression will be mega high now so will pickup better at higher revsso there will be no problem with clearance then mate Quote
