problem with the glanza...just wont hold a bar no matter what i do.got a hks actuator running with a hybrid.holds .7 fine on low but in high its set at bar on a hdi boost controller but wont hold.checked all pipe work and everything ok. any ideas??
doubt if its actuator leak as nearly new actuator,only fitted it bout month ago
Ive herd nothing but shit reports about these HDI controllers as of late, have you tried removing the controller and adjusting the actuator to run a bar just off that? Also when you say it wont hold a bar do you mean it hits a bar then drops back down or do you mean it wont get to a bar?
Sod the EBC's not a great fan of them
i prefer mechanically adjusting the boost im not the greatest fans of electronics. try naffing off the electric boost controller and doing it mechanically and if that solves it fuk the EBC off
yea gets to a bar but then drops back to around .7
yea gunna try doing it maually on the actuator weekend.
thought the hdi were decent controllers obviously not
