steviet Posted August 12, 2009 Posted August 12, 2009 I am trying to fit a nardi boss kit to my ep91 uk spec,and having a feew problems,1) Cant get the bottom of boss to fit properly to steering column,because of black indicator cancelling ring.2) Cant get horn working properly.can anyone help?cheers steve Quote
steviet Posted August 12, 2009 Author Posted August 12, 2009 Is Is there anything missing from the kit so that i can fit it? Quote
steviet Posted August 12, 2009 Author Posted August 12, 2009 Can anyone help me out please,need help Quote
randomhero Posted August 12, 2009 Posted August 12, 2009 hi mate, post some pictures up of the airbag bit removed and i'll be able to shed some more light as i've just put mine on.. Quote
steviet Posted August 12, 2009 Author Posted August 12, 2009 its basically just a small round bit of black plastic that sits into the white frame that holds the wiper and indicator stalks if you know what i mean?Did you have anything more in your kit that isnt in the pic?cheer stevie Quote
randomhero Posted August 12, 2009 Posted August 12, 2009 nah mate, had a straight boss and thats it.. all i had to remove was the wheel, airbag, the black airbag plate once the steering wheel was off.. and then boss fitted straight on..Did you make sure the airbag plate was facing the right way with Top facing upwards.. i kno it sounds stupid but hey.. lol Quote
steviet Posted August 13, 2009 Author Posted August 13, 2009 I removed the airbag plate completly,the centre piece that turns with the yellow wire,and the surround that it turns on. Quote
steviet Posted August 17, 2009 Author Posted August 17, 2009 some pictures of the steering column,do i need to remove black plastic cancelling ring? Quote
steviet Posted August 17, 2009 Author Posted August 17, 2009 Or does this airbag spool still need to be on? Quote
steviet Posted August 17, 2009 Author Posted August 17, 2009 can anyone help me out,wanna get it fitted. Quote
randomhero Posted August 17, 2009 Posted August 17, 2009 remove the airbag spool, then line your boss up with the steering column, the back of the boss kit will have holes that line up with it.. make sure there lined up and it should fit straight on.. give it a little pressure pushing it on and then that should be it.. Quote
steviet Posted August 18, 2009 Author Posted August 18, 2009 my boss kit does have holes on the back of it but dont line up with black plastic cancelling ring,piece of shit,were did you get you boss kit from and how much was it?cheers stevie Quote
randomhero Posted August 18, 2009 Posted August 18, 2009 got it off ebay.. cost like 20 including postage.. Quote
steviet Posted August 20, 2009 Author Posted August 20, 2009 Stevie, as chance would have it I found an old ragged Nardi wheel and boss from an EP82 breaker the other night. You are welcome to pop down at some stage and we'll see if we can figure it out. Two heads are better than one and all that.Jay Not a problem Jay cheers,im gonna have another look at it over the weekend and see how i get on.cheers stevie Quote
steviet Posted August 20, 2009 Author Posted August 20, 2009 cheers randomhero for your help, would you have a link to the supplier on ebay? Quote
randomhero Posted August 20, 2009 Posted August 20, 2009 http://cgi.ebay.co.uk/Toyota-Starlet-Steer...14#ht_500wt_749there ya go fella.. make an offer of like 17 or summit.. Quote
steviet Posted August 20, 2009 Author Posted August 20, 2009 Is this the supplier you bought from mate? Quote
