Bit Of Help Need With A Fuel Pressure Regulator
I have a rrfpr on my n/a I also have a corolla inlet manifold.
I was running glanza injectors for a while but there is no way to control fuelling on a standard ecu.
I'm sure corolla injectors will be bigger than the starlet so probably having the same problem as me.
A rrfpr can't control the fuelling just the pressure.
Hope this helps
Gary
