hi,
just got the car back from having a healthcheck and setup,
if i drive it at a bar or under it has no signs of slipping, but when bumped up over a bar and planted it just shoots off the limiter.
the clutch was only replaced 10k ago so should still be ok..?? :p (standard clutch)
im going to order a new upgrated clutch but i would like to no what power the standard clutch can take,????
and is it just the power of the car thats doing this?
current spec..
gt spec hybrid
hks actuator
ab88 fmic
zisco compact mani
zisco decat
P flow ss exhaust
uprated fuel pump
fpr
greddy profec EBC
green front mount filter
jam fcd
cheers in advance, any help is greatly apreciated :unsure:
cheers
jamie
the standard clutch is rated at standard power, if you've increased the boost, then no wonder it's slipping. it's torque that kills clutches, not bhp.
i had a stock clutch slip after about 5k, due to increased boost, so yes, thats the cause, and it's to be expected.
if you want a clutch to handle the power then invest in an uprated one, and not one of those '35% uprated' exedy heaps of shit.
