Project C.F.A Posted August 25, 2009 Posted August 25, 2009 My Rev gauge has 6 wires:2x Red2x Black1x Orange1x GreenIve put the reds and orange together and put to a live feed so when ignition is on the light comes on and Ive earthed the Blacks. But ive put my green wire into the Ig- in the diagnostic box but nothing happens when I rev?Can anyone help with what may be the problem? Could it be because I have put the 5efe engine into and kept the 4efe ECU??Cheers liam Quote
Veldugo Posted August 25, 2009 Posted August 25, 2009 The gauge have shift light? Maybe the other colors are there for the shift.Did you test the gauge with direct conection? just try for make shure the gauge is working ( for logic you have to use the black and red cables) the black one goes to the black cable without stripes on the ingnition cap. Quote
ToyotaTech15 Posted August 25, 2009 Posted August 25, 2009 By diagnostic box do you mean the black box used to extract trouble codes?I'm not sure if you can take a rev pick up from there, I took mines of the distributor but had to use a toyota manual to find out what wire to useGary Quote
Project C.F.A Posted August 26, 2009 Author Posted August 26, 2009 Ive done a test from the battery and the rev gauge lights up. Its an AutoGauge gauge.I mean the black box in top right of the bay Quote
ToyotaTech15 Posted August 26, 2009 Posted August 26, 2009 Don't think you can take a pick up from that box, it's just for diagnostics.Take it from the distributorGary Quote
Glanza_Ragger Posted August 29, 2009 Posted August 29, 2009 theres a connector next to the distributor with 2 wires, it should be the black oneif you dont know where the distributor is you should get an electrician to do it.. its the thing on the right hand side of the rocker cover, with the king lead going into Quote
Project C.F.A Posted September 1, 2009 Author Posted September 1, 2009 Ive got the distributor and the little plug with the 2 leads but mine doesnt have a king lead as its the N/A so do I still go to the black wire of the 2? Quote
