Help !
I have two wires that im not sure where they need to go.
ECU pin numbers are 2 &11
Pin 2 is neutral starter switch
pin 11 is Engine crancking signal
The colour is black they have a white stripe and an occasional silver dash, the eventually join into each other, all of the diagrams i have show them joining into internal plugs but the other end gose into the engine bay- what dose it connect tooooo help!!!!!
