GT Phayer Posted August 31, 2009 Posted August 31, 2009 wen driving alone and go over bumps sometimes it makes a slight rattle from the n/s/f wheel you can here from in the car ive had the car on the ramp and everything is a solid as a rock any help ????? Quote
GT Phayer Posted September 13, 2009 Author Posted September 13, 2009 could this be a cv joint ????? Quote
Shahzad Posted September 13, 2009 Posted September 13, 2009 I had a similar problem on my starlet. One of my brake pad retaining clips was missing, which caused the pad to rattle against the calliper.Take your wheel off and have a look at your brakes.Hope this helps. Shahzad Quote
GT Phayer Posted September 13, 2009 Author Posted September 13, 2009 ok cheers the wheel bearings are fine it doesnt do it all the time though ;) Quote
andy.i Posted September 15, 2009 Posted September 15, 2009 check the top nut on the suspesion is tight, thats what caused mine Quote
GT Phayer Posted September 15, 2009 Author Posted September 15, 2009 yer everything is tight its sounds like its coming from directly behind the wheel Quote
EN V Posted September 15, 2009 Posted September 15, 2009 ok to eliminate the pads rattling try and recreate the rattle on a perticuler bump/hump and then try it with your foot slightly on the brakesif it stops then its pad rattle like Shahzad says Quote
Jae-Glanza Posted September 16, 2009 Posted September 16, 2009 I Fixed a similar issue on my Glanza only last week! It was the bronze cover that the split pin goes through on the cv joint.When i changed the cv boot, i didn't Fit the split pin back in tight enough and it was rattling sooooo bad.hope this helps pal. Quote
GT Phayer Posted September 17, 2009 Author Posted September 17, 2009 is that on the main hub nut your on about mateive notice that wen the rattle happens sometimes when i press the brake i get a nock to you can feel through the brake pedal and hear on the passenger foot well ????? any ideas Quote
GT Phayer Posted September 23, 2009 Author Posted September 23, 2009 turns out its were the car has been lowered and the shafts at more of an angle its rattling :S:S how can i solve this ??? Quote
