hi every one.
just wanting to know if i am gunna need a gt map sensor instead of my NA sensor? will be running emanage blue, with a 3 bar map sensor, so will the emanage just do away with it? or will it be used at any point?
Jay
There usually plumbed inline with the stock sensor bud, so id assume you would need a gt sensor? not 100% certain though.
I know for a face my gfs brother just got his gt fitted with an emanage and the tuner plumbed the 3bar sensor into the stock sensors line.
depends what ecu youre using. if youre using a gt ecu youll need a gt map.
if youre turboing your NA and piggying off of that with the emanage. the stock NA one will be ok.
youll need the 3bar one for either setup as the stock gt one is only a 2 bar sensor.
Sorted :)
