Tha Dragon Posted August 31, 2009 Posted August 31, 2009 Hi There guy's don't know if anybody has tried this but i have a stock Actuator and just for the time being i just wanted to know if i could loosen the actuator and put some washers 2 on each bolt and then put it back on to see if it could have any affect?I have a weakened actuator that's why wanna do this for the time being? (after that i'll be hunting for a HKS Actuator)Could it work? what say you guy's?Thanks in advanceTha Dragon Quote
StarletRick Posted August 31, 2009 Posted August 31, 2009 if its weak, then itll still creep. itll just creep to a higher boost.do it properly and get a new actuator. if you had a decent actuator, washers would work though. Quote
Tha Dragon Posted August 31, 2009 Author Posted August 31, 2009 if its weak, then itll still creep. itll just creep to a higher boost.do it properly and get a new actuator. if you had a decent actuator, washers would work though.Thanks,Cause now when i run it only let 2 of the boost lights go on and i really miss to see full boost on my car when all 3 lights go on you know,So you advice me to wait untill i could get the HKS actuator?Thanks in advance Quote
StarletRick Posted September 1, 2009 Posted September 1, 2009 you still running the stock solenoid? try the bypass trick, see if that helps. it sounds lke you have a leak somewhere or the solenoid id dead, its fairly common. Quote
Tha Dragon Posted September 1, 2009 Author Posted September 1, 2009 you still running the stock solenoid? try the bypass trick, see if that helps. it sounds lke you have a leak somewhere or the solenoid id dead, its fairly common.Already did that,but i noticed last night when i push it in third gear all 3 go on but i was running on open downpipe so i think it's my actuator to,but i'll take it a try and order an HKS actuator to see if it stops.Thanks. Quote
