Tubo Options
hi thought id start a write up on turbo options, il keep working at it but if any of you can add to it feel free.
hi flow turbo - expand
hybrid turbo - expand
externaly gated setups - expand
different trims and compressor maps -expand
different turbo ranges
td series
Mitsubishi Heavy Industries' (MHI) turbocharger nomenclature, such as TD04-13G-6cm2, requires some explanation. "TD04" and "TD05" refer to the turbocharger housing (either turbine housing or compressor housing or both), including the center housing (or CHRA or cartridge section). There are different styles of the basic housings and these have different suffixes appended to the basic designation, such as TD04L, TD04H, TD04HL, TD05, TD05H, and TD05HR.
Mitsubishi does not seem to use seperate designations for different size turbine wheels, other than the TD04, TD04H, TE04, TD05H, etc., designation. The "6cm2" in the model name is similar to the A/R ratio used by other manufacturers.
Like A/R, the smaller the size of the "cm2" number, the faster the exhaust gases will discharge onto the turbine wheel, and so the faster the spool up will be (less "lag"). The size of the "cm2" number or the A/R ratio also determines the amount of exhaust gas backpressure and, thus, reversion into the combustion chamber. A larger "cm2" number (or larger A/R) means less backpressure at high exhaust flow.
6 cm2 = 0.41 A/R
7 cm2 = 0.49 A/R
8 cm2 = 0.57 A/R
9 cm2 = 0.65 A/R
10 cm2 = 0.73 A/R
11 cm2 = 0.81 A/R
12 cm2 = 0.89 A/R
-tdo4 141 different varients
vf series
garret series
gt spec (180-200)
td12 (200-240)
greddy tdo4 11b (190-210)
mitsubishi tf035 (200-250) found on forrester turbos. a smaller more responsive turbo to the tdo4
tdo4L 13G (200-240 *270 forged 1.6bar) very popular turbo upgrade
tdo4h 15G (200 - 240 *280 forged 1.6bar) found on the mitsubishi evo. has a different bolt flange. note the H stands for high capacity
greddy tdo5 12g smallest of the tdo5 range almost aking to a tdo4. is capable of more power and responds like a tdo4 in most cases.
tdo5h 14b
tdo5 16g. (310 +) this is the turbo you use if you want bigger power its laggier than any mentioned yet but give you a big bank on a forged engine
tdo5 18g (330+) bigger again
tdo6h 20g (400+)
T25
T28
T3
new technology garret ballbearing turbos.
these utilise the latest ballbearing technology and are the best responding and resistant to lag
im just going to skim over the popular options for the starlet
gt20
gt28rs
gt30
sard turbo kits
greddy turbo kits
blitz turbo kits
links to compressor flow maps
alot more to do and still to finnish
links
link 1
link 2 pdf
  • 4 weeks later...
I've got some pics of a greddy 18g if your needing some. Aswell as HRF tub kit pics..
Also Is there anyway I can upload an excel file to the forum? If not I'll whack it on me server and link it here..
