Kennedy Posted September 3, 2009 Posted September 3, 2009 Does anyone know what the standard size for the lower-inner rear bushes are?I have two options 35mm or 50mm.Thanks Quote
motion Posted September 3, 2009 Posted September 3, 2009 Does anyone know what the standard size for the lower-inner rear bushes are?I have two options 35mm or 50mm.Thanksi think you mean 335mm or 50mm you have to look under your car and then you will see how long your bracket is,335mm or 50mm. Quote
WallaceGlanza Posted September 3, 2009 Posted September 3, 2009 Those sizes really don't make sense? The rear lower arm bushes are the one's you'd change when using a whiteline antilift kit or similar, is that the one you mean?The front lower arm bushes are 34mm for the glanza if you mean that. Quote
Kennedy Posted September 3, 2009 Author Posted September 3, 2009 ^^thats the one mate..i'm finally looking to fitting my Anti Lift plates from Idrees and want to change the bushes aswell. Quote
motion Posted September 3, 2009 Posted September 3, 2009 33.5cm bushes?not the bush, the bracket is 33,5cm longlook here:http://i138.photobucket.com/albums/q257/Hi...os/IMGP1514.jpgand some starlets have a 50mm long bracket.you must look what kind of bracket you have!sorry, sometimes it's not easy for me write good enough in english that people understand what i mean Quote
Kennedy Posted September 3, 2009 Author Posted September 3, 2009 ^^Sorry mate i get what you mean now i read it wrong Quote
Kennedy Posted September 3, 2009 Author Posted September 3, 2009 The front lower arm bushes are 34mm for the glanza if you mean that.So i'll need the 35mm poly bushes right? Quote
WallaceGlanza Posted September 4, 2009 Posted September 4, 2009 I can't say for sure on the rear lower arm bush, its been that long since I removed the bracket that you measure.I assume you're looking here: http://www.priracing.com/section.php/426/1/starletAs I said if you're doing the front lower arm bushes its definately the 34mm one's you want, for the rears you'll have to go measuere your mounting bracket on the car to see what size it is. This one here: http://www.toyodiy.com/parts/p_J_1997_TOYO...AGMQY_4802.html (48652 as it says on pri) Quote
The_Notorious_C_A_T Posted September 4, 2009 Posted September 4, 2009 My front bushes that are the front ones infront of the anti lift kit where 34mm ones for my gt, but they where new wishbones from toyota Quote
