  • 4 weeks later...
Doesn't any body else know if the first Clutch kit fit's a EP91 Glanza V 1997?
if not does this 1 fit?
Exedy 16800
Thanks in advance
Should fit in theory, though don't quote me on that.
The MK1 MR2 and the starlet/glanza have the same exedy clutch kit. If you check the exedy website the clutch kits all have the same part number. That kit says its for the 1.6 MK1 MR2, which should be the same.
Jason :thumbsup:
  • 1 month later...
Hi Guy's,
Wha's up, i just recieved my exedy stage 1 racing clutch and this sunday i'll be changing it and see the difference but i have a question.
Do i have to change the gear-oil when i replace it? and if so what kind of gear-oil should i use?
Thank in advance
Tha Dragon
Yup best to change it, 75w90? about 2lt?
undo the bottom nut to drain, then re-fit
undo the middle and top nut and fill thru the top one, when fluid drips from the middle hole you have enough.
If you have an LSD the oil you may require will be different
Ok Thanks for the advice mate.
