EN V Posted September 15, 2009 Posted September 15, 2009 when i got my glanza v it came with a triple pillow pod and 3 gauges1>boost in psi2>oil temp not working3>oil preasure not workingcan anyone tell me where to connect these gauges to and where to get the sensors fromcheersjohn Quote
ToyotaTech15 Posted September 15, 2009 Posted September 15, 2009 You will need to get a sandwich plate for the gauge sensors to screw into,it goes behind the oil filter, here is a picture of my one,If you fit one to a 4EFTE you will need to grind a bit off the power steering bracket as the oil filter will hit.What type of gauges fo you have? do they have sensors?Hope this helpsAny more questions just askGary Quote
Sparky Posted September 15, 2009 Posted September 15, 2009 I had one of those for my Defis Gary and when it came to fitting I put the sandwich plate in place and the threads wasnt long enough to screw the oil filter back on, I can see you got three threaded things but I take it they are for the sensors? Quote
EN V Posted September 15, 2009 Author Posted September 15, 2009 i have oil preasure and oil temp but no sensors any ideas where to get them from and where to get the sandwich plate fromcheersjohn Quote
ToyotaTech15 Posted September 15, 2009 Posted September 15, 2009 The three gold threaded bits screw over the original oil filter thread ro extend it i think,Gary Quote
