Asad Posted September 19, 2009 Posted September 19, 2009 I have a adjustable ARB fitted on the hardest setting? (hole closest to the bumper) when going over bumps etc i can hear squeeky noises i took the yellow rubber bushes off and greased them up but the grease doesnt seem to last long (2-3months)......what grease can i use to stop the squeeky noise?? i used a lithium all purpose grease previouslyAsad Quote
Driver Posted September 19, 2009 Posted September 19, 2009 that grease should do, you grease all 4 areas to grease on both sides ? outside and inside the bushes on both ends, and on the rear beam inside and flat edge ? Quote
Asad Posted September 19, 2009 Author Posted September 19, 2009 I took the the two yellow D shaped bushes off put shite loads of grease in them and put them round the bar again and tightend up everything. Quote
Driver Posted September 20, 2009 Posted September 20, 2009 to be honest pal thats all you can do apart from grin an bear it Quote
