gtt yo Posted September 27, 2009 Posted September 27, 2009 old turbo is struggling with upped boost due to actuator, mani, decat etc. want to put hybrid on but the studs on my turbo are rock solid. could i get some bolts that are a bit shorter than the studs and just swap turbos and bolt my decat into turbo.cheers john Quote
Dan Evans Posted September 27, 2009 Posted September 27, 2009 just get replacement studs from toyota mate, ul never get them fuckers out of there, best to get everything you need first before starting the job mate. Quote
Steve GT Posted September 27, 2009 Posted September 27, 2009 agreed with dan. while your doing it you may as well put new bolts on always better to go newdo it cheap do it twice remember lol Quote
gtt yo Posted September 27, 2009 Author Posted September 27, 2009 so does nayone have a prt number for the new studs? also as turbos hybrid. will ct9 studs matter?cheers j Quote
Dan Evans Posted September 27, 2009 Posted September 27, 2009 studs will be the same buddy, just go into toyota and give them your frame number and they will find them for ya, cost me about 6quid for the lot Quote
gtt yo Posted September 27, 2009 Author Posted September 27, 2009 had alook on toyodiy. that prt number site in the technical section. the studs be the same as whats from turbo into manifold?thanks to you both for helping.cheers j Quote
Dan Evans Posted September 27, 2009 Posted September 27, 2009 no the studs are different mate, the ones from turbo to mani are bigger than turbo to cat. Quote
