chanelle1234 Posted October 4, 2009 Posted October 4, 2009 as above guys. I have purchased a glanza s ecu and herd that it wont work in other n/a's, so what is needed in order for it to work with no problems.chanelle x Quote
rmsnoel Posted November 12, 2009 Posted November 12, 2009 CHECK OUT THE THREAD IN ELECTRONICS SECTION4E-FE GLANZA S ECU pinout Pin Name Wire color Explanation Connector 1 1 RSC Gray Rotary Solenoid Close - Cold Idle Speed Control #2 TE1 3 THW Green-Black Water Temparature Signal 4 PIM LightGreen Pressure Intake Manifold 5 THA LightGreen-Black Intake Air Temparature 6 IGT Black-White Ignition Timing #7 IGF#8 FAN9 NE- Blue Part of the IIA (Intergrated Ignition Assembly) 10 OX White Oxygen Sensor (Lambda Sensor) 11 STA Red(M/T) or Red-White(A/T) Engine Cranking Signal (Starter Switch) 12 #10 Green Injector Pulse 1 & 3 13 E01 White-Black Computer Ground 14 RSO Black-Red Rotary Solenoid - Cold Idle Speed Control #15 TE216 E2 Brown-White Sensor Ground 17 VTA18 VCC LightGreen-Red Throttle Position Sensor (pin 1) #19 NC #20 CF21 NE Green RPM Signal #22 IPV#23 KNK 24 E1 Brown Computer Ground 25 #20 Yellow Injector Pulse 2 & 4 #26 HT Connector 2 #1 SEL --------???????????????? 2 BATT White-Green Switched Battery Power (+12V) (EFI Main Relay) #3 CCO Unknown Check Connector Outputs 4 FC Green-Red Circuit Opening Relay (Fuel Cut) #5 ELS3#6 ELS2#7 ELS4#8 NSW9 +B Black-Yellow Switched Battery Power (12V) 10 W Green-White Warning Light 11 EGW Unknown Catalytic Converter Temparature Warning Light (Combination Meter) 12 AC1 Pink A/C Switch Signal System (12V to Aircon Computer) 13 SPD Violet Speed Signal 14 ACT Black-White A/C Cut Control System #15 ELS1 Unknown Electrical Load Signal System 16 VF Green-Yellow Check Connector OutputstHE CONNECTORS MARKED WITH '#' ARE THE DIFFERENCES BETWEEN UK 4EFE AND JDM GLANZA S Quote
Steve GT Posted November 12, 2009 Posted November 12, 2009 just out of interest why you bought an "S" ecu chanelle? Quote
