What Do I Have To Do To Get My Glanza S Ecu Working
  • 1 month later...
CHECK OUT THE THREAD IN ELECTRONICS SECTION
4E-FE GLANZA S ECU pinout
Pin Name Wire color Explanation
Connector 1
1 RSC Gray Rotary Solenoid Close - Cold Idle Speed Control
#2 TE1
3 THW Green-Black Water Temparature Signal
4 PIM LightGreen Pressure Intake Manifold
5 THA LightGreen-Black Intake Air Temparature
6 IGT Black-White Ignition Timing
#7 IGF
#8 FAN
9 NE- Blue Part of the IIA (Intergrated Ignition Assembly)
10 OX White Oxygen Sensor (Lambda Sensor)
11 STA Red(M/T) or Red-White(A/T) Engine Cranking Signal (Starter Switch)
12 #10 Green Injector Pulse 1 & 3
13 E01 White-Black Computer Ground
14 RSO Black-Red Rotary Solenoid - Cold Idle Speed Control
#15 TE2
16 E2 Brown-White Sensor Ground
17 VTA
18 VCC LightGreen-Red Throttle Position Sensor (pin 1)
#19 NC
#20 CF
21 NE Green RPM Signal
#22 IPV
#23 KNK
24 E1 Brown Computer Ground
25 #20 Yellow Injector Pulse 2 & 4
#26 HT
Connector 2
#1 SEL --------????????????????
2 BATT White-Green Switched Battery Power (+12V) (EFI Main Relay)
#3 CCO Unknown Check Connector Outputs
4 FC Green-Red Circuit Opening Relay (Fuel Cut)
#5 ELS3
#6 ELS2
#7 ELS4
#8 NSW
9 +B Black-Yellow Switched Battery Power (12V)
10 W Green-White Warning Light
11 EGW Unknown Catalytic Converter Temparature Warning Light (Combination Meter)
12 AC1 Pink A/C Switch Signal System (12V to Aircon Computer)
13 SPD Violet Speed Signal
14 ACT Black-White A/C Cut Control System
#15 ELS1 Unknown Electrical Load Signal System
16 VF Green-Yellow Check Connector Outputs
tHE CONNECTORS MARKED WITH '#' ARE THE DIFFERENCES BETWEEN UK 4EFE AND JDM GLANZA S
