dave200 Posted October 5, 2009 Posted October 5, 2009 dunno if this should be here or in engines sorry if in wrong section but does this look ok or cheap sh*thttp://cgi.ebay.co.uk/Lightweight-Relocati...id=p3286.c0.m14dave Quote
-LiNkS- Posted October 6, 2009 Posted October 6, 2009 I bought one of those in the US...Its a great buy...but one problem.....if you still going to use the oem relocator on the block and Power Steering , you have to get a smaller oil filter bypass adapter, it will not fit cause oof the power steering arm is in the way and is only about 1/8 space clearence from the filter to the arm space.you wil have to get one of these... http://www.y2kota.us/images/5adof.jpg ... which is the exac tsize of the OEM oil filter... the one that comes with the kit cater for both bigger and same size filter.....I'll say its a good Buy Still Quote
WallaceGlanza Posted October 6, 2009 Posted October 6, 2009 You really want to be fitting a thermostat with the oil cooler too which that kit doesn't have, otherwise your oil temps could run too low. Quote
Sparky Posted October 6, 2009 Posted October 6, 2009 Hate to say it Cal just bought one of those kits, looks like he didnt have a problem fitting it but not sure if his PAS pump is back on yet?I was also looking at this kit and its a pretty good option for the cost Quote
