eventualy found some info on how to do this.
The physical fitting is just a direct replacement. But the wiring has to be changed as follows.
the only wire that isnt shown is the power to backlight wire, should be a solid green wire in the far right socket. not too sure.
two quick notes: pin 1 in the first glanza socket needs a ground but it is not linked to the tacho ground like i thought. there should be a
spare ground (brown) in one of the sockets.
pin 10 on the second socket of the starlet is the power wire for the rear fog light indicator, which the glanza doesnt have, so
just cap it with something.
i might make my own version of this in a much easier to follow diagram.
