Ep91 Headlights
My headlights are all yellow and discoloured and dont appear to be as they should. Can you split the headlights into two parts to clean the insides as i can see watermarks, dirt, dust etc inside the headlights. Thanks guys
M
alwight mate :harhar: aint seen you in a while lolz
i take it you have an ep82 yea?
not sure how to clean the insides of the lights out
you can split the lights. just put them in the oven for 40 mins to loosen the glue
is that how you get the back lights in two pieces then?
and what temperature in the oven do you put them safely without them cracking mate?
obviously you dont stick them in at 200 lol
No mate i have an EP91 still, think i just need to get inside of the lights to clean them and then reseal them with some sealent.
I'm a bit apprehensive of the oven lol i'll melt them ha
I once split 206 headlights in the oven... its an absolute bastard to do, but then again is was french.
I think i recall ending up at around 100 degrees, but only for limited amounts of time becuase like you said... you dont want to melt them lol
But start at 50 odd and just see how it goes :harhar:
Mitch
use a blow torch lightly,
ive split 106 ones, i started at 80, and think went to 120 until i split them
is this a new ep91?? just i know of one that just sold up your way, and there is another reason there discoloured inside
