JAG Posted October 19, 2009 Posted October 19, 2009 I just got my mits on a HKS boost gauge with interface controller and I'm eager to get it all set up but I've got no instructions to help me outAnyone got them fitted in their car as I havn't got a clue where to start?Any help would be much appriciated and i can post up some pictures if need beThanks in advance Quote
StarletRick Posted October 19, 2009 Posted October 19, 2009 pics, i can probably help you but have no idea what it is ^^that interface thing sounds a bit defi-esque though. youll probably have to wire the controller up. then plug in the gauge. Quote
JAG Posted October 19, 2009 Author Posted October 19, 2009 Cheers for the swift responce mate The meter interface thing is like a control unit which you can jack a load of HKS gauges into and run them all together as oppose to having millions of wires running all over the car I've emailed HKS Europe but not got any word back then I've sent messages to a few people who are selling them on Ebay to see if they'd be able to send me a picture of the instructions (bit cheeky i know) Anyway here's some pics I know this bit below you link up to the vacume pipe just in front of the driver in the engine bay with a 3 way splitter but i thought I'd post up the pic anyway So pretty much theirs 3 extra plugs that im not sure about as in where they plug in the 1 off the boost gauge then the 2 in the same pic (1 big female 4 prong and 1 little male 3 prog) Quote
JAG Posted October 19, 2009 Author Posted October 19, 2009 Im now thinking that the 2 plugs might plug into the ECU and the 1 off the gauge is for running the the connection to the vacuum pipe if you dont have the interface unitBut I've got to wip to uni now so I'll have a little look when i get back Quote
StarletRick Posted October 19, 2009 Posted October 19, 2009 yeah, its the same as the defi. first of all tidy up that disgusting chopped wiring! you need to wire the control unit up to some power source. then plumb the sensor into the bay and get a reading for it off of the map sensor hose. then plug the sensor into the right port on the controller. then plug the gauge into the unit. there will be extra wires for the ecu on that to read voltage and rpm etc for other HKS stuffs. but you wont need those. its hard to explain via text! look at an instruction manual for the defi-link system. it will be almost exactly the same. itll give you an insight as to how it works. the ony difference is the defis have a seperate loom for powering the unit, yours looks like its integrated into the daisy harness. Quote
JAG Posted June 12, 2010 Author Posted June 12, 2010 Just encase anyone else gets one here's where the wires go Red = 12V supplyOrange = 12 v ignitionWhite = lights (so the meter lights up at night with the lights)Black = Ground Quote
