nickep91 Posted October 19, 2009 Posted October 19, 2009 right i have a 5e head and cams which i was lookin to run on my 4e can i do this? will i see a power gain when maped wit it on ? and what else will i need other than ie: head, cams, valves and 4e head gasket ?any help will be apriciated thanks nick Quote
Jozinobi Posted October 19, 2009 Posted October 19, 2009 Please check here for more 5EFTE info.There is some more work involved.Joz Quote
StarletRick Posted October 19, 2009 Posted October 19, 2009 5e head is the same as the fte. the springs are different, so youll need fte springs. aside from that it is the same. just time it up as a 4e not a 5e and youre away. Quote
riko666 Posted October 19, 2009 Posted October 19, 2009 If you have an FHE head then yes, slight bump from the higher lift/longer duration camshafts Quote
nickep91 Posted October 19, 2009 Author Posted October 19, 2009 yer i got 4e head as well so basicaly use the vavle springs from the 4e . why do i need to do this is there any power gain in useing the 5e head as i have a 4e as well just nee to no wether its worth doing ?thanks Quote
nickep91 Posted October 19, 2009 Author Posted October 19, 2009 its just a 5efe are the vavles not bigger in the 5efe than in the 4efte ? and the cams better ?as this would improve power ? Quote
riko666 Posted October 19, 2009 Posted October 19, 2009 Valves are the same, camshafts on 5e are eeeeeever so slightly different, but, insignificantly so Quote
nickep91 Posted October 19, 2009 Author Posted October 19, 2009 o right so no point then really shall i just use the 5e cams in my 4e head then ? Quote
chr15_7_t_ Posted October 19, 2009 Posted October 19, 2009 what would hapen if you used a5efhe head on a 4efte with the normal springs? Quote
riko666 Posted October 19, 2009 Posted October 19, 2009 5E-FHE I think should be the same (I'll check part numbers) as it had a raised rev limit compared to the normal 5E-FE (7500rpm as opposed to 6200rpm), most people just bolt on Quote
chr15_7_t_ Posted October 19, 2009 Posted October 19, 2009 cheers..wats the standard rev limit for a gt turbo? Quote
chr15_7_t_ Posted October 19, 2009 Posted October 19, 2009 happy days..thats one thing i didnt think about was the springs :/ Quote
