I'm in the middle of putting Paseo clocks into my EP, but I'm stuck :D
I'm about to swap the pins/wires that plug into the back of the speedo, but can't seem to get the metal pins out :S
These are the pins I'm on about, and yes I have removed both white plastic tab things, but still no luck! :thumbsup:
http://i9.photobucket.com/albums/a70/RRmon...et/DSC00485.jpg
Any idea as to how I can get them out? I don't wanna try yanking the wire out in case it tears..there must be some sort of tab but I can't seem to find it?!
Thanks,
Amjad
When I done this i used a safety pin to push down inside where the wire goes in then you give it a little tug.
Should be a pic of where to stick the pin in the How 2 guide for it
When I done this i used a safety pin to push down inside where the wire goes in then you give it a little tug. Should be a pic of where to stick the pin in the How 2 guide for it
Cheers Sparky! :(
I've just managed to sort it out ;) you gotta poke the bit under the long metal tab then pull it out
Thanks for the help!
